I have a new to me 1996 4.3 L MerCruiser. The boat was given to me by an older gentleman who’s a friend of a friend that said he was told the exhaust manifolds were bad and that it had some electrical gremlins.
I got the electrical sorted out and I got the boat up and running. The manifolds appear to be a little crusty around the manifold flange is between the riser and exhaust manifold but other than that appear to be okay. I rang my buddy up and asked if he could ask the man in more detail what was wrong and he said one side was running hotter than the other and it blew a hose off the manifold.
Today I got the motor up and running to operating temperature, I let it idle for about 15 minutes then I took it up to about 1500 RPM and took temperature readings all over the manifolds.
-The manifold temperatures in the center of the manifold opposite the mounting face were about 100° and left and right or within 2-3° of each other.
-The risers were around 95° and again left and right 2-3° of each other.
-The elbows showed a larger temperature difference one side Was about 105° and the other side was about 125°
- The lower exhaust tubes after the elbows were about the same temp from left to right around 105°.
Any ideas why one elbow might be so much higher then the other? I’m also not really seen where any hoses could blow off from other than the rubber connectors on the elbows.
