I have a 1988 Alpha One Gen 1 with a 3.0 GM engine. Bought the boat last summer and have been spending this winter doing maintenance from the front of the engine back to the propeller. Anyway I found the U joint bellows with a good amount of gear oil in it. Disassembled the input shaft and found a pretty good groove in the yoke where the seal contacts. I've read choices are to either replace of course or else install new seal slightly deeper to get it to a new spot on the yoke. Is that really a practical move? Does it work well? The surface of the yoke is in great shape inside the spot where the old seal contacted. If I get a new yoke will the gear mesh still be correct? I will reuse all of the races, bearings and shims and have them hanging on a wire in the order they were previously installed. Mercury service manual number 6 says to just install with components in same order when just doing a u joint job but describes the proper shimming procedure for a major rebuild when installing new bearings, gears etc.. Does just a new yoke require measuring the gear mesh?
Will post a couple pics.
On a side note..told my wife's boss's husband about my plans and he said he had a few tools I could borrow as you can see in the other picture. Got lucky I guess.
