Welcome Guest - Sign Up today
No announcement yet.
Alpha one outdrive oil compatibility
  • Alpha one outdrive oil compatibility
    I've got a mercruiser alphaa lx 3.0 with a alpha one outdrive. I got it last year I don't know what type of oil is currently in the outdrive. I'm looking to change the oil and noticed ; Mercury High Performance Gear Lube plus says not to mix. I'm gonna drain what ever is In there out. The residual left over isn't a problem I assume not knowing what it is? I was gonna change the old and add; Mercury 92-858064K01 Marine SAE 90 High Performance Gear Lube.
    seems there's a ton of conflicting info on what to use and I don't have a manual.
    I also see ; Quicksilver 858064Q01 High Performance SAE 90 Gear Lube .
    Not sure which to use?
    Use the High Performance Lube. Mercury and Quicksilver are the same thing in different bottles. It's like Dodge and Mopar or Ford and Motorcraft.
    BOAT SPECS | FORUM HELP | STARCRAFT FORUM | SHOP iBoats
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      Thanks
