just bought a nice boat... so i thought. need some help here. had no chance to water test, only on hose due to time constraints...ooops! bought it, took it to the lake and oh boy do i have engine problems.
on a tight budget, bought a 2001 Reinell 200C 21ft Cuddy with a Mercruiser 5.0L EFI original engine with an alpha 1 stern drive, engine shows 210 hrs on the clock and cosmetically looka clean and rust free. here the issue:
1) took it out first time to lake, all fresh fluids, fresh plugs and fresh gas (boat was stored for years by previous owner
2) boat had no power in the water under load, RPMs maxed at 1800
3) revs out high rpm under no load (on hose or reverse, of course)
4) no visible cracks in any exterior surface of engine or drive was told stored winterized indoors and its a native pheonix, az boat we dont get hard freezes.
5) got boat home, there was water in the oil. light water such as from piston blow by...lightly milky not too much volume increase on dip stick levelm
6) drained oil, pulled plugs and oh boy, port side cylinder #7 shooting water out the spark hole
7) low compression on all but one cylinder (below 120) around 90s
8) zero compression on starboard side cylinder 2
9) previous owner had just done a impeller, so I expect it got hot. guy got seriously agressive after contacting him a week after buyinh boat to ask if it got hot or something on him befee he sold it. i was nice, he got crazy instanly via text so hiding something.
10) i am hoping it is manifold gaskets, head gaskets and hope i wont find any metal parts in the heads or cylinders.
11) there wasnt any banging, clacking, rattling or anything else at all when turning over the engine.
any thoughts, ideas, recommendations, help, or suggestions on how to approach this in november. boat wont run, cant be winterized properly. about to do emergency top end tear doen and inspection. only ever done PWC and automotive work. no stern drive experience. ex military and just had a baby so working on a seriously tight budget or i would just take it to a pro.
