Changed the oil in preparation for winter storage and sent oil samples out for analysis. The report for one engine came back with with high levels of the elements found in antifreeze along with wear metals elevated. Roughly 50 hours on the oil and 650 on the engine. Engine seems to be running OK at cruising speed but the last couple times I used it the temp gauge for that engine was about 5 degrees higher than the other. Exhaust risers were replaced in 2017. In 2019 some old pieces of impeller were found in one of the cooling hoses creating a partial blockage which caused the engine to go into limp mode at around 3800 RPMs The raw water impeller was intact so I don't know how long the broken pieces were in there. Problem seemed to be resolved but now I'm concerned that the previous problem is related to the current issue. Check of the coolant level revealed that the level was down some but I did not notice any excessive steam in the exhaust or smell any antifreeze fumes. The oil I changed out has been sitting for about three weeks and no water or antifreeze has separated from the oil. Compression test was done last year and was excellent in all cylinders. Hopefully I have caught this in time.
I'm new to Inboard engines so I need some help diagnosing the cause in a logical manner. Unfortunately the boat is being hauled this week so I will not be able to run it to test.
