Hello, I'm planning to replace the impeller in my 79 mercruiser 260 with a "pre-alpha" MC-1 drive. I took the boat out the past weekend and temps went up to 190 degrees. I'm going to replace the thermostat while I'm at it since this boat is old and I don't know all of its history. The serial number on the drive is 5462056 and right next to that number it says 1.50R. Does anyone know how I can find out which water pump kit I need? I'm fairly certain it's either sierra #18-3316/3317/or 3319, but I want to make sure. It looks like the main difference is the pump bases.
On an unrelated side note I also replaced the points and am trying to adjust the timing. I have the boat idling at about 650 rpm to check the initial timing, but when I use my light the timing mark isn't holding very steady, it jumps around a degree or two in either direction. Is this normal or an indication of wear in the distributor? maybe the weights? I have replaced the cap, coil, rotor, condenser, and plugs so those are fresh.
