The original post was because the motor went into guardian mode, so there was a low pressure issue either by sensor or actual. The sensor was changed and have same readings, so guessing the sensor was not the issue. - That's not entirely correct - the thread was started because the motor went into guardian mode due to a pressure sensor which was reading 0.0psi. After I replaced the sensor I am no longer going into alarm, however the pressure readings remain "low". I have not been able to find any published values those values are supposed to be - according to Mercruiser customer support, the magic number is >2psi at idle, but in reality folks seems to be getting anything from 0.7 to 5 psi at idle.
The only reason I keep re-hashing this is because I want to prevent my engine from going into Guardian mode because of the same issue again. Frankly, I couldn't care less what the pressure value is - all I care is if my engine is operating at the correct temperature.
Fresh water = closed cooling and gets mixed up quite often with folks boating in fresh water. Just something we will always deal with, because folks have not seen a HX filled with "fresh water", always AF - Point taken - closed cooling it is
Tubing can be connected to inlet of the HX - I need to look at the routing of the hoses but that sounds like a good spot
Use a Tee fitting so you can have both sensor and mechanical gauge installed. - I could do that, but I feel like I already proved that the replacement pressure sensor is reading accurately. I had some doubts initially, when I compared it's values to an inexpensive mechanical gauge, but it turns out it was the mechanical gauge that was reading inaccurately. Unfortunately we are splitting hairs anyway, since we are dealing with such low pressure values (for ex. 0.7psi vs 1.5psi)
