new plugs, points condenser, rotor, distributor was removed, timing was set, has spark, tested with spark test. boat mechanic said that the engine has plastic timing gear which may be the problem?
No backfire, firing order used 1-8-4-3-6-5-7-2, rotor turns, spark test positive for all 8 plug wires, no water in oil, timing set a 10 degrees Before top dead center, on compression stroke,
Not 100% sure if distributor rotor is correctly pointed to number one cylinder. Tried moving distributor when spinning motor with remote start button while ignition switch in on position, still no response. Can the timing be checked with a timing light while the engine is only being turned by the starter?
