Hello all,
My 1989 boat has twin 5.7s with Alpha One gen 1 drives. The port engine (0C523213) is getting hot only when running at or near WOT. It runs normally at 3500 rpm but above 4000 it climbs. I've never seen how high it goes as I back off when it gets up to the 200 range. Stbd engine does not have this problem. I replaced the entire water pump assemblies in both drives over the winter.
Port drive also received a new upper half (SEI).
Thoughts on what might be causing this?
