carrera205
- May 2, 2011
- 45
Just finished building a 5.7 vortec. I hooked the red power wire to the switched power on the coil and then grounded the black wire to a grounded bolt. When the engine wouldn’t fire I started checking things out and figured out it wasn’t getting spark until I unplugged the ground wire from the electric choke then it would fire right up. Once I had it running I tried to plug the ground back in to test and sure enough it kills the engine.
Whats happening here?
