328ifun
- Jun 25, 2019
- 35
Is there anything else I need to check? My only concern now is the condition of the transom, since the boat sat for awhile in the rain I'm worried about it being rotted. It was fine the last time I took it out but I found the water in the storage compartment on the floor of the boat. The section inside of it (flooring) has rotted so I'm hoping water hasn't entered the inside of the boat.
Do you all recommend sealing the compartment off since its rotted, it has a wood covering over it right now? I'm going to get some 3M 5200 and reseal the sensors and screws that hold the swim deck on the back of the boat as additional transom precaution.
I've replaced:
ujoint bellows
exhaust bellows
water line
water gasket
gimbal bearing
shift cable/bellows
points/plugs/ign cables
Fresh engine oil
Fresh gear oil
new battery
Fresh gas
Impellar and gaskets
Everything looked fine on Muffs and boat starts and stops as it should, shift cable is aligned correctly
Anything else?
I've replaced:
ujoint bellows
exhaust bellows
water line
water gasket
gimbal bearing
shift cable/bellows
Fresh engine oil
Fresh gear oil
new battery
Fresh gas
Anything else?
