kschnebly
- May 15, 2013
- 64
Pulled my head on my 454 after having the crankcase fill with water. In the process I ran a compression test and found that the #5 cylinder was 0 psi. All others were goo . The valves is sitting much deeper and the tension on the spring is much less. Did lose the valve seat? If so wouldn't I expect some piston damage?
