nola mike
- Apr 22, 2009
- 5,068
Was running great, then started missing over 3k rpm while pulling a river. So far:
1. Did a half assed carb rebuild. New Accel pump, otherwise reused everything in the carb. Looked pretty clean. Filters did as well.
2. Broke a plug off in the head. Managed to get it out. New plugs (pic after about a mile of running) and distributor cap. Mallory electronic conversion.
3. Checked timing
4. Compression 120-160 (?)-120-100 immediately after getting the old plug out. After running that mile I was 140 in #1 and 120 in #4. Not good, but I don't think bad enough to make it miss?
5. Cleaned all engine grounds etc
Still guessing this is fuel related, but I have a coil from 4.3 that I want to swap in (one of the posts on the old one is loose).
1. Have a spare carb and bought a kit to rebuild
2. Want to check fuel pressure next. How do I plumb into my solid fuel line?
Anything else I need to be thinking of?
3. Checked timing
