FT, just tried to send you an PM and there was no send button. No secret but does side track a bit on the thread.
How can I/we get some of the info you can locate? We have the basics but all the one off differences makes it ruff to help. There is another thread going on where the guy has 1 beep per minute (cat motor) and I can find nothing which there even would be a 1 beep.
The first s/n range for 6.2 shows the FP reg in question. If we look at the second s/n range there is another p/n and does list 43 psi
Anyway a cheat sheet can be found?
Unfortunately something's amiss with the Message system again as I can't even read them unless I use the recently discovered work around from the last time some of us couldn't open the PM's, etc..
Here's the work around link if needed,
https://forums.iboats.com/privatemessage/notification
Truthfully a lot of the differences I bring up for the newer MPI stuff is just stemming from memory of the changes that were to be coming over the years before leaving the marine business professionally plus using that experience, I'll try to search things out to try and help better where possible.
For the older stuff I have an old August 2007 Merc marine tech handbook to look up things like the injector names I used above, the regulator part numbers vs what PSI they should be and what the color markings on the regulator means as in what PSI the color means...Pink = 30 psi which is the part number we all listed above.
I have noticed with Bam Marine ever since they switched their parts catalog around to a newer system a few years ago now, the serial number search feature seems to be a 60/40 spit if your going to get the right serial number range, right engine model listed for the true engine type the serial number actually belongs to such as some will show with 555 ECM type engines, the 5.0 MPI, 350 MPI, 6.2, MPI...Yes they may all use the same parts catalog but it will tell you you're looking up a 6.2 engine model but in all actuality the serial number belongs to a 5.0 when searched out someplace else.
Ceboyett, it's good to hear you located the issue being a fuel injector on number 6 cylinder...what prompted you to check the fuel injectors over?
