JesterOMA75
- Jun 8, 2019
- 8
I have an early 80s boat my son purchased for us to work on. It was supposedly running last year but other than that we know nothing about it(and nothing about boats). We are mechanically inclined and have worked on cars. After replacing the entire ignition system and adjusting timing, and cleaning the carb we got it running only to find that it was heating up. After removing the lower unit and replacing the impeller we now have a running boat that does not overheat. So we water tested it and it ran very poorly and had a leak somewhere around the transom.
So we got a pressure tester and checked the engine. 120, 40, 40, 110. Seems like the middle 2 cylinders are very low. Also found a tear in the shift cable bellows.
Our next step is to pull the head and check the head gasket and clean/inspect/adjust the valves and replace the shift bellows.
Any words of encouragement or advice?
