Mark A. J.
- Jun 18, 2019
- 7
I am a new boat owner and haven’t found an answer to this question elsewhere yet. I have a 2007 Maxum 1800 ST3 with Mercruiser 4.3 MPI and Mercruiser drive. I noticed that port front engine mount was loose. So loose that I don’t know if the top nut was even touching. I tightened it down and then noticed that it was much lower (3/4” maybe) than the front starboard mount.
It had had some power steering fluid leaked on it so was very lubricated. I thought maybe that the bottom nut may have vibrated down with vibration, weight, and lubrication. I pried it up a bit and spun the bottom but up maybe 1/4” inch. It still sits lower, but now I’m second guessing moving it at all.
Im not even sure how the engine driveshaft aligns to the drive. Is this a precision fit? Should I put it back down roughly to where it was, bring it up in line with the other side, or check alignment somehow?
I was was thinking that since I was able to pry it up, that it was likely an indication that it wasn’t being properly supported at that corner. If there were an alignment problem, would I be able to identify that by vibration if I fired it up now and engaged the drive?
Thanks!
Thanks!
