Welcome Guest - Sign Up today
No announcement yet.
Steering Cable removal Merc 4.3
  • Steering Cable removal Merc 4.3
    I have a 4.3 and I want to change the steering cable. I was able to remove the cotter pin and pin from the one side but I cannot for life of me get the nut off on the other side. It looks like it’s spinning or rotating the tube when I try to loosen the nut. Am I doing something wrong? It’s a rack and pinion steering system with hydraulic.
    Any help would be great. Thank you
    Ayuh,..... There should be a set of wrench flats on the tube to hold it,......
    • #3
      I will get a picture, put the isn't any flats, just threads unless the flats are not near the nut. I will look when I get home today.
      Thank you
      • #4
        regular steering, power steering?
        NO PERSONAL QUESTIONS, THIS IS WHAT THE FORUM IS FOR.
        • #5
          Power but I got it.
          thank you
