Hi All,
In 2014 I replaced my 1987 3.0 liter engine with a 3.0 MPI it has ran well for me for the last four years. My old engine used a 10 pin connector to the engine and the MPI engine had a 14 pin connector I bought a adapter from mercruiser and hooked it up and everything was fine. Until the other day when I was unable to turn off the motor with the key. When I disconnected the boat wiring harness from the 10 to 14 pin adapter the boat continued to run....after that I disconnected the the 10 to 14 pin adapter from the motor and the motor shuts off. When I completely remove the adapter from the boat and checked continuity between pins 5 & 6 on the 10 pin side of the adapater I read zero resistance any idea whats happening ? ...should pins 5 & 6 be connected/shorted
