ShoalSurvivor
- Aug 1, 2012
- 217
This is good advice... if you forget the chaser string, you’ll be sorry...
I attempted to use the "replace cable with wire, use as guide for new cable jacket" approach. Didn't work for me because the wire was too short
but, for those who wind up having to thread a new cable, have no fear... it's easy.
I used a bent coat hanger with a loop on one side, wider than the cable housing, but smaller than the end housing brass. there is a perfectly clear path from the starboard side of the engine to the initial penetration of a shift cable housing. you can look directly down from above the transom entry point, and see the the end of the housing. Simply slide the coat hanger from the starboard side, level with the cable (the path is perfectly level with the cable entry point on the transom) and gently loop over the cable housing. Then pull lightly as someone else gently feeds the cable housing in. Once you clear the very first corner (3-4" in), it's trivial to route the cable.
