tylerdale101
- Jun 8, 2017
- 30
Hello, I am looking for some help with a noise my mercruiser is making. I can't locate it, I bought the boat with a cracked block so I sourced a used engine and rebuilt it. But it makes a noise now. The noise is a quiet rhythmic knock like knocking on a solid wall and is directly proportional to the rpms. The noise DOESN'T occur at idle, only occurs at or above 1000 RPMs. I have used a stethoscope to try and locate the noise, from the best I can tell it is the loudest on the passenger side oil pan and rear end. I have tried isolating the problem by removing belt to eliminate accessories and removed plug wire individual both didn't help. Any advice would be great!!! Thanks for your time and help!
