hi people. I need help. I Just took over my late father in law’s project, he built a Riva Aquarama replica, code name Volare.
He passed away in the final stages of completing the boat. Twin engines, Mercruisers 6.2 lt V8s, 700 bhp.
Given my sailing and nautical background, have been able to successfully make most of the systems work. I am at a standstill though regarding the hidráulics for the helm system. The boat has an Ultraflex pump already wired, but the two leads that must go into the ignition key are not installed. I have absolutely no clew as to where or how they connect into the electrical harness of the ignition circuit. Both engines have a classical 4 point turn key system (off, acc, on, Run).
The hidraulic ayatem will not even power up unless it detects the ignition is in the on position.
If if any one can give me a detailed guide as to where these wires must go (they are a pair, one runs into each key respectively), I would greatly appreciate it.
Let es me know if you need images to understand the layout.
