Welcome Guest - Sign Up today
No announcement yet.
Filters for 350 mpi motor
  • Filters for 350 mpi motor
    I started a thread on identifying fuel water seperator filters for my motor and my Genny....I bought two for what a parts site showed I should have on the motor. I figured/hoped rinker used the same for both. This worked out fine for the generator...but for the motor, well there is not one. This is the second time I have changed fuel/water filter on a new to me very overwhelming boat. The generator one is mounted on the firewall...I guess I assumed that was for the motor the first go around and did not look at the lines closely and figured the Genny did not have one. There also is not a fuel cut off valve for the motor- there is one for the generator. The line for the motor comes from the tank to the filter to the fuel pump. The only place I can see where it might go is a strainer for the generator...is this normal?
    I getting my filters together for spring tune up....I'm looking at my parts list from previous years...it looks like I had ordered a OEM fuel water separator for the motor...and a siera 18-7845 for the genny....now it looks like the oem is no longer available and says to use the siera which happens to be the same filter my notes say I ordered for the genny...that possible? I suppose if Rinker was put the genny in and they already use the same for the motor that would make sense....? I'm not near the boat to check. Guess it can't hurt to order the two of them, If I can't use it this year I can use it next year...
    • #3
      for the motor.
      Ayuh,.... To save everybody havin' to dig through yer other threads,.....
      How about you tell us what ya got,......
      I use Napa fuel filters,.....
      Their 3225, is the standard shorter Merc fuel filter,....
      The Merc filter heads all use the same threads, 'n o-ring,....
      The depth of the filter changes with the different part numbers,.....
      • #4
        The motor I'm good on...2006 350 MPI...just looks like Rinker used the same one for the generator... I just ordered them both and if I need to get another for the generator I can deal with that, they are cheap! Thanks,
        • #5
          Is what normal? You say there is no filter but also that the fuel line goes from tank to filter to fuel pump. Which is it? What are you looking for?
          The engine system and generator system need to be considered 2 separate units that just happen to share a common tank.
          83 Sunrunner 16.5 120 merc Alpha 1 drive SOLD 8/1/13
          1996 Crownline 202BR
          5.7l EFI 0f791070
          Bravo I drive
          GMC Yukon tow rig
          • #6
            Sorry, what I'm saying is the generator has a ball fuel valve, a fuel water sepeseper and a fuel filter. The engine only has the in line fuel filter, no cartridge.
            • #7
              Being an mpi it should be new enough to have a screw on filter.
              5.7l EFI 0f791070
              Bravo I drive
              GMC Yukon tow rig
              • #8
                The filter on the engine is a combined filter and water separator, in the single spin-on element...
                Chris...
                xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                The world takes on a whole new perspective when viewed from 100’ below.
                1972 Bertram ‘Bahia Mar’ 20
                2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
                (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
                • #9
                  Ayuh,.... The gen-set only needs 1 fuel filter, the second is just an added leak point,......
                  The fuel water separators ARE a fuel Filter,....
                  The fuel filter canister should be on the forward starboard corner of the motor, just before the primary fuel pump,......
                  'n the motor's fuel line shouldn't need a ball valve, as there should be an anti-siphon valve, at the tank's outlet,....
                  If the fuel pump ain't suckin', no fuel leaves the tank,.....
                  • #10
                    Well, there is no spin on filter other than the one on the Genny....and I did notice when I pulled the in line fuel filter off, I had no fuel leakage. The is no antisyphon valve either. So in the process of all this my water pump has apparently taken a crap on me.....friggin boats!
                    • #11
                      350MPI... It will have a filter. Starboard side, just under the front of the exhaust manifold. If not a spin-on, then an element inside the fuel pump. #28 in the drawing... https://www.mercruiserparts.com/bam/...31752/13884/60
                      In future, please add more detail to the description of what you're working on. '350MPI' just isn't enough. Add the engine serial number and what drive is behind it. I was only able to work it out by deduction.
                      Chris.....
                      • #12
                        If you are not firmiliar with the screw on filters, they look like an oil filter.
                        5.7l EFI 0f791070
                        Bravo I drive
                        GMC Yukon tow rig
                        • #13
                          If it's an engine for a Bravo drive, it doesn't have a spin-on/screw-on, it's an element inside the fuel pump... (have a look at the drawing I posted the link to).
                          Chris......
                          • #14
                            Yep, familiar, just don't have one. My fuel pump is a cylinder about 7" long located right under the alternator. I will try to post.
                            • #15
                              Oh and bravo lll, 2095 motor...I will get the numbers...someone please post something to this so I can find the thread!
