Welcome Guest - Sign Up today
No announcement yet.
4.3 L Mercruiser 190 or 220 hp?
  • 4.3 L Mercruiser 190 or 220 hp?
    I just bought an 07 Tahoe Q4 SF. It has two barrel carb. The title says 220 hp. From what I have read the 220 hp motors have four barrel carbs. Is that true?
    Not quite. 4.3MPI is 220hp, the 4.3TKS, which is a 2 bbl carb, is 190hp. After about 1997 there were no more 4.3s with 4bbl carbs.
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    The world takes on a whole new perspective when viewed from 100’ below.
    1972 Bertram ‘Bahia Mar’ 20
    2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
    (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
    • #3
      Thank you sir.
      • #4
        Hi rickety
        not doubting your mechanical ability, but are sure it’s a 2 barrel carb you have ? Only asking because the title says it and most of the boats like yours that age will have an mpi I would think. The mpi still has what at first glance can look like a carb under the air filter. With 2 sections that might look like a 2 barrel carb perhaps. Just a thought.
        • #5
          I think the OP would be able to tell the difference between this....
          Click image for larger version
          And this........
          Just saying....
          Chris.......
          • #6
            [ATTACH=JSON]{"data-align":"none","data-size":"large","data-attachmentid":10705297**[/ATTACH]
            And this........
            [ATTACH=JSON]{"data-align":"none","data-size":"large","data-attachmentid":10705298**[/ATTACH]
            Just saying....
            Chris.......
            Never know Chris. That’s why I said about not doubting the ability of the gentleman. I’ve seen some things on here that would make you think.
            I’ve also seen many mpi engines that don’t have the mpi cover fitted at all. To a newbie, might throw the thinking ? Just saying.
            • #7
              It's definetly a 2 barrel carb.
              • #8
                Then definitely 190hp.
