Assembly in Cold Weather
FreeBeeTony
Any problem in starting to re-assembly my engine in temps in the 30's?.........i.e. installing heads.
Have ALOT of other projects planned for the spring and trying to get a head start.........
achris
More fish than mountain goat
'Head start'.... :lol::lol::lol::lol::lol::lol:
dingbat
Two questions
1. Does the torque specification give you a temperature rating?
2. Has torque wrench been calibrated per ISO?
Unless your installing o-rings in the space shuttle, a no to either question null and voids your concerns about the temperature
Ayuh,..... My fingers go numb at those temps, handlin' cold steel,...... :rolleyes:
gm280
It gets kind of cranky in cold weather, but piston on and ring up the parts and get that head start... :laugh:
Scott06
You can do it for sure just fingers go numb as mentioned. In my younger days sure, getting to old for that stuff now... also usually need whiskey for my hot coffee vs cold beer.
harringtondav
As long as the critical torque parts are at the same temp. at torque up, you'll be good. Steel and iron have nearly identical rates of thermal expansion. Fastener stretch on aluminum parts will be a teeny bit more when they warm up, but negligible compared to torque wrench repeatability.
FreeBeeTony
Installed both heads and adjusted rockers today...........temp was high 30's(?).
Got done what I wanted to!
