Welcome Guest - Sign Up today
No announcement yet.
Play in outdrive
  • Play in outdrive
    Hello all,
    i have a lot of play, left to right in my alpha one gen 2 outdrive. Does I pay sell a kit to repair this? I recall there being a kit that you drill a hole in the transom assemble to repair
    You may be able to reduce the play by tightening the two bolts at the top of your gimbal ring. You'll need to turn the steering hard each way to get a back up wrench on the inside nut.
    '96 Larson 174 SEI BR. 4.3LX 4 bbl Weber s/n 0F786604. Alpha One Gen II s/n 0F709315
    • #3
      !st you need to figure out exactly where the play is.
      1999 Powerquest 260 legend
      502 mpi
      B1
      • #4
        ^^ +1
        94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
        95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
        07 Seadoo GTX
        Merc Adults Only VP Adults Only
        G-Dad always said "First Liar doesn't stand a chance"
        • #5
          Originally posted by AllDodge View Post
          ^^ +1
          +2
          You're gonna feel awful when you install a kit to fix the steering swivel and find the play is from worn gears in the helm at the dash. Just sayin'. Investigate more.
          BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
          Please, no PM's (Private Messages) regarding boat/engine problems.
          That is what the forums are for.
          Only forum/moderator issues will be answered in PM's.
          • #6
            or if the issue is v-bow wander
            Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
            1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
            Past Boats
            1970 Wooster Hellion - Merc 9.8
            2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
            1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
            What’s behind you doesn’t matter.Enzo Ferrari
            • #7
              Play is Definatly not in the wheel, play is where the arm connects in the transom assembly
              • #8
                More then likely your going to need to rebuild the gimbal ring and steering pin. Can try to tighten the bolts as mentioned, but most often when this happens, its to late for that to work
                07 Seadoo GTX
                • #9
                  I had alot of play in my gimbal. I was able to tighten the bolts and take it out. I have used the mercury kit where you drill two holes in the assembly to get to the pinch bolt and upper nut. Not fun. I would try to tighten the bolts first. One old timer told me the bolts are shouldered so you cant go to far . If that does not work there Is a company that sells a repair kit where instead of drilling holes you cut the front of the assembly out I will find it and post it here
                  • #10
                    http://www.jrmarine.com/products/gimbal_repair.htm
                    • #11
                      This is what I will do next time there is also a video on YouTube on how to do it
                      • #12
                        I'm glad this came topic came up. So should there be no side to side play at all when you try to move the out drive by hand, or will there always be a "little"? Is there spec on this?
                        • #13
                          There will always be some, but not much. Any looseness in a tight gimbal assembly should be limited to the pin and hole clearances in your tiller arm and the steering cyl. yoke. But there are several other locations in the steering system that can become sloppy. Tracking these down takes a helper to move the outdrive and steering wheel while you observe.
                          • #14
                            Thanks! I'm pretty sure everything is A OK, it's just something I've never checked or thought of checking.
                            • #15
                              Play is definately not in the wheel, play is where the arm connects in the transom assembly
                              'Arm to transom assembly'. Would that be the steering lever (13) to the swivel pin (14), or the swivel pin into the gimbal ring (1)? With these sorts of problems, you need to be VERY specific to get the right solution. Here's a diagram of all the parts, and their correct names to help everybody out...
                              It also helps to know what we're talking about, so for everyone else, it's a 2001 5L EFI, so it also has power steering. When looking at these sorts of thing, that information is also quite important.
                              And with that in mind, could there be wear in the pin (24) that connects the arm to the power steering clevis? Or in the pin in the clevis that connects it to the end of the steering cable?
                              Click image for larger version  Name:	gimbal ring.JPG Views:	1 Size:	155.3 KB ID:	10703149
                              Chris........
                              xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                              The world takes on a whole new perspective when viewed from 100’ below.
                              1972 Bertram ‘Bahia Mar’ 20
                              2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
                              (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
