hey gents,
First post for this forum. i can probably imagine how many times this has been asked but im going to ask anyway.
so i have a 1986 470 mercruiser in a 22 foot Caribbean commodore that i recently purchased at a very good price, when i first got the boat it was having issues with heating and water contaminating the oil.
I then ended up replacing the head gasket and ran the boat with the muffs no issues would reach about half temp.
the starter motor ended failing so the boat sat for about 2 weeks while i waited for a replacement after the new starter was fitted i fired the old girl up and after about 10 minutes it started over heating :mad-new::mad-new:.
I then put a new impeller kit on and now it runs fine pumps plenty of water only reaches half temp and thats after about 30 min at 2000rpm.
Now the problem im having is after i run the motor im losing about 1 litre of coolant basically the exact amount the riser is holding and im contaminating the oil with water again and seems to have a fair amount of steam coming out of the valve cover keep in mind the boat isn't getting hot.
All i can think is either cylinder head is cracked the riser gasket has failed or a faulty shutter?
Has anyone had a similar issue or know a cause any help would be great.
thanks fellas.
thanks fellas.
