Dima_NZ
- Dec 23, 2018
- 26
Hi guys. After a bit of advice.
After a few months of no use, went to run the boat - and it the engine literally "stopped" going into reverse. This was pulling away from the marina, so in the water. We went out anyway....
Back on the trailer, the problem still persisted. My buddy and I traced it all the way back to a very stick lower shift shaft (see separate thread at bottom of this post in the footer for full details of that repair), but this repair alone did NOT fix the issue. Here's the video of it happening on the trailer:
https://youtu.be/-lHACQir8q8
Here are some facts:
1. Remote control cable travel from WOT forward to WOT reverse is exactly 80mm, so right within spec.
2. The adjustment lug for the lower shift cable is right at the bottom of the slot on the shifter plate.
3. The 6-inch centre-to-centre distance on the lower shift cable was adjusted to spec, and the process followed in general with the remote cable etc.
4. The ONE PART of the spec that my system currently fails is that there is around 18mm of play in the lower shift cable with the prop locked in FWD and me standing on one of the blades to keep it there - there must be 14mm or less play in this scenario according to the manual.
5. Using the paper-cut-out template and wit the sterndrive unit off, prop locked in forward, I got 12 degrees of play - so right within spec. According to the manual, this means that the problem is either in the shift cable, shift lever or upper shift shaft. Shift lever and upper shift shaft are in great condition, so I suppose I need to replace the lower shift cable (nut of which is fully seated into the bellhousing, all greased, no obvious leaks). Perhaps it just stretched with time?
6. Lower shift shaft rotation is pinky-light, and shift crank/spool seem to be within spec.
So acknowledging the possibility of a stretched lower shift cable (that's outside spec), would this issue be causing a sudden stop to the engine when shifting INTO reverse? a few times it shifted into reverse just fine, and stayed there happily, but on most occasions (as this video caught), it will just "hit a wall and die". It's a very firm, immediate engine stop. I also built a little "shifter interrupt by-pass" tool, which looks like a padlock with a wire coming out-and-into the female connector to isolate this - and even with this by-pass gadget connected, the engine died a few times shifting INTO reverse (a time when the shift interrupt switch shouldn't be doing anything anyway, huh?).
In any case, if you guys have some words of wisdom, I'm all ears. Really stuck for ideas, short of the lower-shift-cable.
Cheers,
Dima
Cheers,
Dima
