are you talking the Gen V big block from 1991-1995?
or are you talking the Gen V 6.0 and 6.2 small block (LS motors from 2013 and on)?
if so, the Gen V LS motors have been used since 2013 in marine motors (Just like the prior LS motors going back to 2006). you need to get a complete marine version, or you need to build a complete marine version with heat exchangers, etc.
to marinize the LS, you need a heat exchanger, a marine exhaust (only available as catalyst exhaust for the LS or expensive headers) and a marine EFI setup. Cheaper to sell boat and buy what you want.
Thanks Scott,
I was just wondering out loud. I see a lot of the 4.3 and 5.7's but no 5.3's.
I have an alum project boat that I'm not sure what I want to do with it,
and am not even sure it's worth any effort/money.
Or just leave it. I don't have an issue with the weight of the 470 or the 4.3, but I think the 5.0/5.7 would be too heavy.
Using your guidance from previous posts, I am looking for mid 90's 4.3, and actually found one, but it wasn't cared for, and is now likely cracked. But I'll keep looking. The "problem" is most of the "donors" actually look better/nicer then the project boat. So the question becomes "why not just a new/different boat?
