a couple of days ago I started my engine (1978 470) and got a panic moment when the audible low oil / high temp alarm didn’t stop after starting the engine. A quick glance at the oil pressure gauge received the panic as it showed 40psi pressure.
i then letvtje engine heat up - alarm still going - to find that the coolant temp gauge wasn’t reading at all.
i guess the 2 issues could be related ?
i tested continuity from the tan water temp wire to the gauge - tested good. I see 12v between love purple and ground at the gauge.
i tested resistance between the 2 terminals on the sender which went from 1.1k ohms down to 700 as the motor heated up.
i guess the wiring gauge and sender are ok ?
that leaves the oil pressure switch connected to the oil pressure sender.
am I on the right lines here ?
many thanks
ron
many thanks
ron
