Hello!, I have 99 Maxum cabin cruiser that comes stock with small block v-8 with 260hp i believe. The outdrive was a alpha 1 gen 2 with 1.47 ratio. I bought the boat about 3 months ago and came with all service done and maintenance paperwork. In 2008 it was re-powered with a 350 mag mpi. The outdrive was already in bad shape and went out after 4 or 5 trips. It had a 14.5 x 17 aluminum prop on it. At WOT i was at 4800 rpm doing about 34mph. The mechanic put on a new SEI 116 outdrive with a ratio of 1.62. I put on a 15x17 Black Max prop and went thru the break in procedure. Now i'm way over the max rpm range of 5000 at WOT. Actually cant even get to WOT. Any reason why he would changed ratio from 1.47 to 1.62? The mechanic wont get back to me and i changed marinas last week.Did he do because i have a 300hp engine now instead of the 260hp stock? Should i increase pitch and go with a 14.5 x19 prop to bring the rpm down. Thanks in advance for any input!
