Ok so here is the problem
I have later rams with an early MC1 drive which has the shorter pin in the aft hole in the drive.
the cylinder bushing is too big to go on the drive pin so what can I do ?
one idea is to remove the shorter pin and replace with the later 10.5 inch pin but getting the pin out is a problem. Any ideas ? Tried a butane torch, hammer and block today and it ain’t budging.
i don’t want to cut and drill it out as I’ll ruin the drive.
another idea is to have a pair of small 1 inch extensions machines to make the existing pin longer so as to take the rams.
ideas welcome please
