Simply amazing how humans can F%&* things up. All that was needed was to retap with a 1/8 pipe thread tap and reinstall the sensor. Are you good at soldering ? I can supply a threaded bushing you can solder on to the housing and install a fitting if the threads are missing from the ps cooler. Try your local home depot, or a quality hardware store that sells brass fittings, a good marine store too
