As the title suggests.
i jist completed a full rebuild of my 470 and forgot to prime the oil pump.
i did align it with the distributor shaft though.
the engine is now fully built and installed in the boat but when I tried to get oil pressure by cranking, it won’t even fill the oil filter.
i removed the filter to find it clean. I tried using an empty bottle filled with fresh oil and connected a host to the oil filter threaded galleryand tried to pump oil into the pump by hand but it’s not accepting it.
what can I do ?
i have a shaft from a dizzy - can I put it on a drill and prime by spinning the pump ?
thanks in advance
ron
what can I do ?
thanks in advance
ron
