Over the past few seasons I have regularly had to add gear oil to the reservoir for my 1999 Alpha I Gen II (coupled to a 3.0L) as it will drop maybe an inch throughout a summer season. I do not have oil in the bellows or oil dripping in the driveway. And each season when I changed the gear oil the oil was clean, no water. My plan was to leave well enough alone, as long as the reservoir loss was small and the drive oil remained clean.
This year was no different, until now. This past weekend I drained water from the engine I found gear oil in the water drained from the upper drain plug, definite blue tint to the water. The water from the lower drain was clear, but the boat had not been run in a few weeks so I assume the oil floated up inside the engine.
Today I winterized and when I pulled the bottom oil screw from the drive the oil that drained from the drive for the first few seconds was mixed with water. So whatever leak that previously was one way is now letting water in and I assume significantly more oil out.
I have the drive off the boat and have the winter to fix the issue; since there is still no oil in the bellows or leak from the prop shaft I will focus on the upper drive shaft seals and lower drive shaft seals below the water pump. I am wondering that since I found gear oil in the engine water cavity if it is the lower drive shaft seal letting oil up into the water pump intake.
I plan to do a pressure test and inspection to find the leak, but I am hoping someone else has seen the type of issue and might be able to provide some insight. Thanks in advance for any help and feedback.
