Welcome Guest - Sign Up today
No announcement yet.
cooling water ice caught in time 3.0L mercury
  • cooling water ice caught in time 3.0L mercury
    I did most of my winterization in October which was non-ethanol gas with fuel stabilizer, changing oil + filter, and fogging engine until stalling. One thing I did not remember to do was drain the cooling water from the engine. The boat has been stored inside a large non-heated garage, and low temperatures were mostly 0 C degrees but there were some minus days in there. Worried, yesterday I went back to cottage to inspect the hoses and cooling water situation.
    First thing I did was I pulled the blue exhaust manifold and block drain tubes and was happy to see water coming out. Then I opened up the 3 other tubes around the water cooling pump to take a look.
    That's when I saw a bit of ice already start forming. I poured some hot water down to melt the ice quickly, let that water drain, then once satisfied most of the water was clear, filled it up with the anti-freeze and hopefully now have truly finished my winterization process.
    Click image for larger version
Name:
    Good catch....
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    The world takes on a whole new perspective when viewed from 100’ below.
    1972 Bertram ‘Bahia Mar’ 20
    2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
    (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
    • #3
      Hate to be pessimistic...are you sure this wasn’t ice melting from a more solid form previously ? Hopefully not. If not, nice one getting to it on time.
      • #4
        Unfortunately, you will not know if there is any damage until you fire it up come warm weather. This is the number one reason so many boat engines are replaced. I drain mine and fill it with coolant and then drain it all out and leave the system empty for the winter. Never an issue.
        • #5
          When I have to do a partial winterization, I do the drain first since it is the most important part. This year I had to do that (drained it in Oct due to cold temps) and had already changed the oil so a few weeks after I drained it, I fogged it thru the cyls and then just filled the engine up with my batch of -26* PG Sierra antifreeze. Always do the drain first, the other stuff is not critical and can wait.
          1988 Four Winns 200 Horizon
          4.3 OMC Cobra
          98 Jeep Grand Cherokee 4.0 Selectrac
          07 Jeep Grand Cherokee Limited 5.7 Quadradrive II
          "While air doesn't freeze....rust never sleeps"
          • #6
            I'm definitely crossing my fingers. Won't know until spring. I just know we didn't have a lot of minus days between the first time I did the oil on Oct 16, and Nov 12th so I am hopeful. On the 12th the drain hoses drained water instantly and fast flowing, if it was frozen solid at one point no way it thawed out to drain like that when temps stayed around 0c.
            • #7
              I'm definitely no expert but had this thought. When I winterize I always run the motor on muffs and get the motor up to temp before I remove all the drain plugs. Then I remove the large hose on the thermostat housing and leave it off. Next day everything is nice and dry and I reinstall that hose and plugs. I don't use antifreeze. Good idea or?
              1996 Glastron 185GS fish and ski
              4.3LX Gen+ (190 hp 2 barrel carb)
              Alpha 1 Gen 2 S/N 0F 845543
              • #8
                I think you'll still have water in the block, so the idea of the antifreeze is to displace the water that is in there. also if you leave things dry then you get corrosion and rust, so I like the idea of keeping liquid in there to prevent that.
                Next year i won't take the water hose off, because now I have to clean it real good to make sure it seals properly with the pump. I'll just connect antifreeze with hose to ear muffs and run it until pink comes out etc.
                • #9
                  nope, there would be no water in the block, not enough to worry about
                  you will take the hose off next year, as that is part of the draining process
                  your thought of connecting it to AF via the muffs and running it until it comes out the exhaust will get you a busted block come spring time.
                  follow the manual. drain everything 9via plugs, hoses, etc.), then if AF makes you warm and fuzzy add it to the t-stat housing with a funnel.
                  Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
                  1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
                  Past Boats
                  1970 Wooster Hellion - Merc 9.8
                  2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
                  1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
                  What’s behind you doesn’t matter.Enzo Ferrari
                  • #10
                    this is about the easiest ever engine to winterize, 2 drain plugs and the big pump hose and raw water intake hose. drain em all and you are really done. Can back fill with AF if you want.
                    4.3 OMC Cobra
                    • #11
                      What I do is drain block PROBE HOLES on risers and manifolds. Pull thermostat so I dont have to worry about that. I soak it in some oil to keep it coated. Fire up on muffs and suck antifreeze through with muffs. Then drain block again and run sump to suck up antifreeze through there. Fog motor and I'm done make sure I fog good. This year I'm not gonna use muffs though because it's hard for these beasts to even run 3 sec with no water. And I'll have them parts taken care of now. I'll just fill hose with antifreeze after draining block
