Gatherusin
- Nov 11, 2018
- 1
1991 Starcraft with 3.0 mercruiser I/O. Since we’ve gotten into cooler weather up north, boat will start up ok and run but after about 5 min it will start to sputter. You can rev the engine and it’ll bounce back but then start to struggle again. It eventually will die. However, after restarting it, it seems to be ok and has no issue. I try and keep it running the first time, reving it as needed thinking once the engine is warm it will be ok, but it’s like it has to die at least once before it will finally just act normal. Thoughts?
