I've got a 2004 Rinker Captiva 232 with a Merc Mag 350 and a B3. It has about 350 hours on it. I bought it with 330 earlier this year. The boat has only ever been in freshwater lakes. I have no idea when the raw water impeller was ever changed.
In order to even see the pump housing I will need to remove a storage tube that is right beside the engine. This will gain some side access but the fuel cooler is still in the way.
Directly in front of the engine is the back side of the rear seats. There is maybe 2 or 3 inches of clearance between the pulleys on the engine and the bulkhead. It's impossible to reach the pump housing from the front. I would need to remove the rear seat and then remove the bulkhead which seams to be one piece with a large portion of the floor. I think the floor section is covering the fuel tank.
So, basically, I've got to tear the boat half apart before I could even lay hands on the pump. How often does this really need to be done? I have no temperature issues at all right now. I'm thinking I should just pay someone to change it for me, analyze the condition, and then watch the temp gauge and see how many years I can get out of a new one.
Any thoughts on this plan? I'm wondering if it would actually be easier to pull the engine then take the interior apart. But, if pulling the engine requires it moving forward more than 2 inches or so I would have to pull the boat apart anyway.
