Oshawapilot
- Aug 2, 2013
- 66
The marina my sister and BIL have paying a ton to winterize their 35' (twin 470) cruiser since they've owned it - the marina service people have been charging them the same as a freshwater engine for their winterizing - something like $150 per engine. Needless to say that's a whole lot of money for what seems to be simply pulling 2 drain plugs out. Easy money for them I guess....
So tomorrow we are going up to winterize the rest of the boat and we're going to do the engines at the same time.
I've done a ton of reading here over the years, as well as this evening, and it seems that from everything I've read, including the service manual screenshots that others have posted, the entire winterization process consists of the following:
1/ Pull heat exchanger drain plugs out from rear of heat exchangers, poke a paperclip or whatever to make sure no blockage and they drain the freshwater fully.
2/ Check coolant from closed loop engine side for proper 50/50 mix.
Done?
Obviously we are doing the other end of season service as well (draining the stern drives, etc), but my main concern is with regards to the engine winterizing. Is that REALLY it?
Done?
