Chris51280
Ensign
- Jan 24, 2018
- 908
I have a 1990 4.3 non balance shaft maercruiser with the 2bbl carb and fluid mounts. I found a 1992 4.3 automotive engine from an s10 for $50. I would like to have a backup maybe something to work on over the winter. I know I can only use the head and block with crankshaft the intake should still be the 12 bolt right? Does the balance shaft pull horsepower? I know the cam should work. Change tje freeze plugs.
any other things to consider? I have the mechanical fuel pump. Does that still work?
