aarons 470
- Aug 29, 2012
- 351
82 glasply merc 470.
Removed old gimble. Feeling inside I don’t feel a hole where the grease would come in from the grease zirk on the side of the gimble. Must be a thin slot?
when I set new one do I just eyeball where that grease inlet would be to the hole in the outer gimble bearing where you add grease? I thought there would be something inside to use as reference?
I think my gimble has the grease connection for the bearing? It is starboard and goes up at an angle into the gimble.
And i looked up what direction the gimble goes in, I’m reading it can go in either direction?
any ideas for a diy set tool?
thanks
thanks
