aarons 470
- Aug 29, 2012
- 351
My engines serial number is 6123990, I’m Stuck on a couple things. My engine wire harness is from another boat, Or should say half of the assembly. The side with the male ends/ plug end came from different boat. Female side was mounted to my boat.
I have added the solenoid to the starter. And added the alternator. Shouldn’t matter with my questions, just incase. I Had previous forum help on this and I also have manual 3. Double checking everything today all looks good. Trying to Wrap up last couple wires, found a problem.
Brown and white wire at back of engine. It is supposed to go to a terminal block. This wire is “ trim sender to trim gauge”
So off the terminal block, Brown/white wire goes to trim sender.
And I need to run a ground wire to sender from same block. Can I ground this anywhere?
And both wires run separate to sender, they don’t connect together at terminal block- correct?
problem 2 up next but related.
