Chris51280
Ensign
- Jan 24, 2018
- 907
I need some advice. I got a lower unit that was what I thought seized up. The upper unit is seized up due to being run without enough oil in it. Lots of discoloration. When I got the lower unit split from the top I could not move it in forward or reverse. I pulled the bearing carrier out the whole unit spun freely. After inspecting the unity, it looks ok. each bearing runs without any problems. The rear thrust bearing has marks on it but no noticeable damage other than the roller marks. I thing it got overheated as well. The gears look to be ok. What is your take on it. I have a complete seal kit and I think if I just replace the forward angular roller bearing I should be ok.
