Sashap
- May 1, 2016
- 145
Sometimes when I slow down from high speed or speed up from idle, I hear a weird bumping clicking noise that sounds like outdrive but not sure. It's almost like the sound made when slowing down from high speed and engine goes to idle but prop is spinning from moving through water fast. The difference is that when the noise starts, it usually will do it forward, reverse or right through neutral. I can't pin it down. It is not always either. I can stop for a few seconds or restart and the noise goes away. If I just try to run through it, there is a vibration I can feel in the boat. Ideas?
