I started the engine (which starts fine, has very good 150 PSI all cylinders, no milkshake in the oil) and immediately found coolant dripping out of from inside bthe flywheel housing.
Question to S.D.: What part of an engine block breaks from using only one bolt to hold this type of starter on?
Ayuh,..... Welcome Aboard,..... Even though this is a thread hy-jack, 'n I ain't Scott,......
There's a core plug behind the flywheel that was probably pushed out by freezin',....
I suspect you'll find more cracks, 'n possibly more core plug problem, once the 1 behind the flywheel is pushed back into place,.....
The reason I say this is,.....
The coolin' water can't build any pressure, 'n can't get any higher in the block, than the core plug that's pushed out,.....
When crankin' a motor on the starter, with only the outside bolt in-place, the entire "Ear" at the rear of the block on that side can be busted off,.....
At that point, the entire block is scrap iron,......
Is there any other way I could temporarily hold the starter in place to see if the boat will even start up? Don't wanna have to pull the motor and everything right now just a cheaper boat
Nope,...... Fix it Right, right now, or the entire motor can easily be turned into scrap iron, as I noted above,.....
