Tarleto1984
- May 28, 2018
- 5
I have a Merccruiser 470, with a Alpha One. Im pretty sure i know what's wrong with it, just wanting a few other opinions. Took it out a few weeks ago and after backing the trailer into the water, I casted the boat off from the dock to pull it back on. It had ran fine all day. When I went to shift it into reverse I got nothing, the engine would reeve but would not engage. Safe for shifting it into forward. Finally I was able to get it to go into forward by slamming the throttle into forward a few times. So I read on one of the forums that it my be my lower unit and to drain the oil and look for metal shavings. I did that and found nothing. The oil looked perfect.
So I read somewhere about a clutch dog, when then sent me in the direction of the lower shift cable. That’s where I am at now. After adjusting it back into specs while the engine is off I can get it to go into forward, the prop will lock when its in forward. Reverse on the other hand only way to get it into reverse is to adjust it way out of specs. Still the prop will lock in forward and reverse. That’s with the engine off. Now when I put the boat in the water it still will not go into gear, unless I slam the throttle forward a few times. I can only use one though either forward or reverse.
So big question I guess is with it locking out of the water then then once its in the water, does that still point to the lower shift cable?
