arminius
- Aug 30, 2016
- 45
Have a 2012 Bayliner with 3.0 TKS I/O and had it professionally winterized and out only 5 times this summer. To my dismay, the the oil alarm went off yesterday. So I checked the dipstick, and no oil!! Didn't even register on the stick. There was some oil under the engine and even some that appears to have sprayed around the engine.
I'm not sure if it was a one-time thing or gradually happened during the summer as I have not been checking the engine.
I checked the oil filter, and that is tight. I did a quick inspection of the engine, and saw no loose tubes. I did a compression check of and 3 of the cylinders came in at 180, and the other at 150.
The only other thing I can think of is the starter/solenoid was recently replaced. Thoughts?
