boaterinsd
- Nov 19, 2010
- 276
My plan was to get it started to see if it ran , which it did. Good sized outward crack starboard side, small crack port side. Was just gonna pull it and swap in a 78 350 I found with good compression. Till I discovered the crack bolt pattern on mine is smaller (one piece rms) and my planned replacement is bigger( 2 piece). So the flywheel that the coupler mounts to is or isn't the same for the older motor?
I am not gonna buy older motor is I can't simply make it work, right. Or do I ?
