hutsonb12
- Jul 11, 2013
- 4
Hey there. I purchased a known seized 1995 Bayliner 2250 with a Gen V 7.4 Bravo 3. Thunderbolt V(i think) ignition. Pulled the motor and rebuilt with .040 bore. Loved every second of it and used this forum for a lot of good info on my first go at a boat build. I finally got the fresh motor broken in after fighting the distributor and old dirty carb. Ran it for 20 minutes and didn't have time to set the idle before dark.
The next day I swapped the carb out for a known good 750.... coughed for a split second once the bowls filled up and then nothing...
I am getting spark from the coil to the distributor but not out to the plugs. Checked with my timing light. I then went ahead and bought a new cap, sensor, and rotor since they were about the only thing untouched from the rebuild. Still nothing. Getting frustrated and hoping to get some additional input on it.
Thanks in advance!!
Brandon
Thanks in advance!!
Brandon
