[FONT="]I found me a 470 with only 66 hours on it, its a 1978 build and I plan to fit the boat with it and take the boat to a remote location in Greece so wanted to do the nasty bits before taking it over. Its been sat in a shed for the past 25 years so I plan to do the following ?[/FONT]
[FONT="]Later alloy exhaust manifold
New starter
Alternator conversion
Pertronix ignition
Rebuild carb
4 Inch HE
Remove watercooled regulator and stator
Headgasket replacement
Cam seal replacement and camshaft inspection.[/FONT]
[FONT="]I wanted to ask if there is anything else I should consider ?
Also is there any nasty surprises when doing the headgasket ? Any common problems ?[/FONT]
[FONT="]Many thanks.[/FONT]
[FONT="]Rake[/FONT]
New starter
Pertronix ignition
Rebuild carb
4 Inch HE
[FONT="]Rake[/FONT]
