First time boat owner here. Have built many motorcycle engines and a couple cars so I'm mechanically inclined, but some of this boat stuff has me completely clueless. Motor is a 2.5 Merc, when I got it the wiring was a mess and would not run. Got that sorted, new plugs, oil and filter, needed a new alternator also, adjusted the carb and it was purring like a kitten and a seemed to run out great in my opinion. It always made a little 'puff' kinda sound that I could hear at idle, almost like a tiny steam engine. I just assumed it was a characteristic of this motor. Boat never gets over 140, and I have no leaks and the oil looks great.
I had it out in Lake Michigan the other day, and about halfway through the outing I noticed the little puff seemed to have turned into a louder tick. At idle, it sounds like it did when I first got it running. Under load past 2k, it's noticeably louder. My first thought was that I had hurt something, since the waves were more than I should have been out in (novice boater, little open bow 19 footer) and I also ignorantly had neglected to trim it down all the way. I never revved it past 3.5k however. After doing some research, I checked the bellows, thinking they could have torn or become dislodged, but everything looks great.
I have heard that some say using multi-weight oil can increase these noises? When I changed it I ran Rotella in it since I have a ton on hand, and was told that diesel oil is the preferred oil if straight 30 is not available. I'm not sure I buy this, as it sounded great for the first 5 minutes of being out.
My next step is to check valve lash, and I'll be well happy is that's all this is. I will say, this does not sound like a clattery rocker to me, it very much sounds like a Jeep with a bad exhaust manifold gasket. :lol:
What has me confused is how the risers and all the marine exhaust/cooling components function. Every 'Merc 2.5-3.0 exhaust leak' thread I find concerns overheating and water leakage. I have none of those issues. I'm a little hesitant to pull the manifold off, it's so foreign to me. I mean, the carb sits on top of the exhaust manifold? I assume the intake is integral passages? Is there water in the system I need to drain beforehand? I sprayed soapy water on the gasket between the block and the manifold and saw no bubbles, but I'm not even sure I'm looking/spraying at the right areas. I'm used to headers and drag pipes!
I do have a Merc stern drive service manual, but this area is quite confusing to me and I'm concerned I'm not understanding things correctly.
Could someone break this down for me, and help me diagnose what may be going on? Pics would be a big help, also. Thanks!
